So while its hard for me to remember exactly how this used to work, but what I find now is, even if "Auto Sync On Play" is turned on, it really only syncs if play is initiated from the Play/Pause button. So if I start the song from one of the Hot Cue buttons, it won't auto sync. This seems somewhat counterintuitive to me, but am just curious if this is something new, or if this has been the way its worked forever, and I'm just no noticing... If the latter, just seems like it might be a nice "option", to have Auto Sync engage from however a song is started.
geposted 4 hours ago
have a look at the smart options try in particular "smartcue"
keep in mind people are always asking for ways to disable features and if something isn't working it is probably off
