If I set VDJ to run dual video output, I can get it to do transitions between visuals
But if I then load a video file, I will need to disable the visual to get the video
And then to enable it again if I play an audio only file next
If I then use VideoAudioOnlyVisualisation to handle it automatically, the visuals starts on the master deck when I load the audio only file, which means no more transition FXs
Is this correctly understood?
geposted 5 hours ago
