Hi everybody!
I kindly ask your help regarding the use of stems 2.0 with a Nvidia RTX3050Ti videocard in a recently bought Asus ROG x13 laptop(there are integrated AMD Radeon videocard and a NVIDIA RTX3050Ti dedicates videocard).
I know that it was hot topic in 2023 but I thought that it had been solved with the updates of Virtual DJ.
The problem is that as I see VDJ uses the CPU (processor) for Stems calculation instead of the NVIDIA RTX videocard altough I have unticked “don’t use GPU” and I have also selected the NVIDIA as the requested videocard to be used for stems. I also tried to set NVIDIA vudeocard as the forced videocard for VDJ in Windows NvIdia settings as well.
Do you have any advice what to do? The version of the driver of Nvidia RTX3050Ti is also the latest.
Thank you for your help!
Regards,
Gábor
Regards,
Gábor
geposted 4 hours ago
