Topic: How to clean up my install
Hi Guys,
I have 2 sets of VDJ folders, one at \documents\virtualDJ\
and another at the more awkward... \users\AppData\local\VirtualDJ\
I'm not sure which is current, I think it's \documents\ I'm using some m3u exports from Crate Hackers as a trial, but those files end up in AppData etc.
How can I straighten this situation out. All my machines are the same, with remnants and mixed up playlist paths.
Thank you knowledge bank.
M
geposted 6 hours ago
It depends which home folder VDJ is using. The old way was documents but then it changed to AppData.
Click the cog in the bottom corner of the settings screen and that will take you to the home folder for the current DJ install.
Each PC could be different depending on when VDJ was installed on it.
