Hello,
I just installed update b9246 and noticed the following:
The V.Effect is not displayed in the skin (see image).
Is this a bug?
Is this a bug?
geposted 3 hours ago
You probably had the Shaders plugin selected before. "Shaders" entry does not exist now as we renamed it to "Visuals" after its big update to include AI visuals.
You just need to select the Visuals plugin once and it will remember your choice.
