Topic: Cue Volume Boost
Hi guys,
I did not find my problem in the forum, so I will ask it here.
I use my laptop for practice purposes and have routed my main output and my headphone to my headphones. Say now a song plays on deck 1 and the volume fader is all the way up, I can hear it in my headphones. If I press the cue button for that channel the volume increases. Why is that? I would like to have the same max volume on the cue.
I can not find anything in the options where I can setup a Cue-Gain or anything. The Mix-Cue is set to 50/50 so it should be the same volume?
Thanks for your help!
geposted Fri 03 Apr 26 @ 11:03 am
DJDVINE84 wrote :
Why is that?
It's because you've routed two outputs to the same place. You're adding the cue output to the main output, so the volume increases.
Trying sending just the cue signal. You should be able to hear the master by using the cue mix knob.
