Hi team,
Just a quick heads-up about the updater.
I’m on the beta branch (I think?, Windows x64, v2026 b9269), and a couple of times now the in-app update has pulled the wrong version of VirtualDJ. When that happens (I click Yes), VDJ is unusable and I have to manually hunt down the correct build on the forums, reinstall, and then reconfigure things like my default folders (e.g. pointing back to my D drive instead of AppData). It adds a fair bit of unnecessary setup each time.
This has happened the last two times, so it might be worth checking that the updater is pointing to the correct version for each release channel.
Appreciate all the work you’re doing though!
Thanks
Thanks
geposted 8 hours ago
Which CPU do you have?
9275 is indeed the current EA release, so it should work
geposted 7 hours ago
