Hi
When I install the ASIO drivers, my Laptop connects straight away and works without any issues, however once vdj is closed and everything rebooted (mixstream and laptop) vdj will not connect again just stops responding!
unless I uninstall both the drivers (v 1.0.3) and reinstall again, Is there a fix so it installs correctly?
Laptop is brand new I7 with Nvidia Geforce Video 6 gig and 16 gig ram Windows 11
thanks in advance !
thanks in advance !
geposted 2 days ago @ 4:55 pm
Sounds like the now famous Win11 update problem:
https://virtualdj.com/wiki/Win11-KB5074105.html
geposted 2 days ago @ 6:14 pm
Thank You IIDEEJAYII your info on a different issue solved this problem for me
Turn off Windows Midi 2.0 :
Go to Settings > Controllers > Missing Controllers > Check the Box "Disable MIDI 2.0"
Or can be done in OPTIONS > disableMidi2 = Yes
I can now connect or disconnect as expected at will :)
Thank You
Thank You
geposted 21 hours ago
