Topic: vd KEEPS FREEZING
VD keeps freezing when i prompt the Denon DJ go pro to connect with it. the denon software is at the latest vesion and work fine on its one - as does VD - both when they connect - it FREEZE time! help please
geposted 7 hours ago
If you're on Windows, disable MIDI 2.0 then reboot and try again.
