Hi there everuone.
Can anyone tell me, when will he have a vdj skin for Rane System one please?
Anyone????
Anyone????
geposted 6 hours ago
There are no controller specific skins any more. Any skin will work especially the default VDJ ones.
geposted 5 hours ago
Hi kradcliffe, thank you for your info buddy, so you are saying that the default vdj skin will work with ok wit Rane system one correct?
geposted 3 hours ago
Yes that's correct. Once the controller is oficially supported you can use the default skin and all features will work.
If you expect a "Screen" skin similar to other Denon controllers (Prime 4, Prime 2 etc), then keep in mind that the System One is not following those implementations, the device is not providing a custom screen design. The official Mapping (work In progress) will just feed the firmware with the necessary data and the Engine OS will display them in a way that cannot be changed.
geposted 2 hours ago
