Topic: Virtual Dj Folder
Hello everyone,
When I create multiple "VDJ folders" (not filter folders) in macOS, I can no longer move them. I mean, the order can't be changed.
This worked with Windows, but not with macOS. Because until this year I only used a Windows laptop and only had my MacBook Pro as a backup, it wasn't a big deal. But starting this year, my MacBook Pro is my main laptop, and this is incredibly annoying.
Do you have any suggestions?
Best regards from Germany
Btw:
Unfortunately, I don't speak English, so I used Google Translate, and I hope I've explained my problem clearly.
geposted Thu 30 Apr 26 @ 11:41 am
Hello,
When I'm on the main "General Discussion" page, I see three posts, the last one written by "Blecy Dalida."
When I go into my post, I only see the post I created. I can't see the replies.
I'm logged in and have "pro" status, but I still can't see anything. Did I open my post on the wrong page, one I don't have access to?!
Can someone please help me?!
The mods come and clean up if any nonsense gets posted, so you're not missing anything exciting.
@OP:
Where did you download VirtualDJ from ?
iTunes ?
Or Atomix website ?
If you downloaded the Apple Store version of VirtualDJ, please remove it, and download again and install the version from this website.
Apple Store version of VirtualDJ has some limitations.
Finally make sure that under your MACs Privacy and Security settings, you have allowed VirtualDJ full access to your hard drives.
Let us know if any of this applies to your case and whether or not it helped you solve your issue..
PhantomDeejay wrote :
@OP:
iTunes ?
Or Atomix website ?
Hi PhantomDeejay,
thank you so much for your reply.
I downloaded it from here (VirtualDJ website) and in the settings / under privacy and security settings, VirtualDJ has full access to the hard drives.
I was a regular white Windows user, and I didn't have this problem. :-(
Maybe you have lockFolderOrder enabled?
Hello Adion,
what is this and where can I see if it's active or not?
Options
esgoez wrote :
Hello Adion,
Hello Adion,
That's exactly it, I found it!
Sometimes it's right in front of you, but you still can't see it... :-)
Thank you again so much!
