Topic: Previous Builds
HI, just recently my VDJ has been crashing/non-responsive (hardware seems fine) upon startup with the Denon Prime Go +, it has only started in the last 2 wks, I want to go back to a previous build -1 e02, to see f it is the build. Where can i find a list of the builds to download.
geposted 4 hours ago
thanks is there a link to an older build it only shows -1, i have downloaded this and is still crashing
this is the sequence I do,
Power up Prime 2 go+ decks
Switch to computer mode
plug in USB cable (driver shows connected )
start VDJ this is the point where it hangs, it doesn't pick up the prime go decks, nor does it come up with the prime go selection pop up
It never used to do this and it is very frustrating. Drivers and firmware are all current, even unstalled and reinstalling the drive
does anyone have any ideas, can I supply some logs for people to check I am using build -1 version
Have you considered it could be the Windows Midi 2.0 screw up?
InMusic drivers are affected by this. Might not be VDJ at all.
Install the latest version of VDJ, disable midi 2.0 in settings then reboot.
Hi thanks,
Enabling the disablement seems to have done the trick after a few resets of everything
Thanks for your help, I wasn't aware that there was an update that messed up the MIDI 2 stuff
Microsoft at their best yet again. InMusic using archaic drivers.
People automatically assume it's a VDJ update causing issues but not this time.
Good to hear you're sorted.
