first buy the FULL VERSION...
crack doesnt work.... trust us.. the software is different!!!
Then select what sound card config u have....
If you only have ONE single line out you will select the first box on the left... to use a mixer u need a stereo splitter.. and then u need 2 adapters to make 1 rca into 2 (one for each channel)... Then hook up leads accordingly....
If you have a 3d card select the second box on the left, and channel 1 comes out the rear and 2 out the front (could be the reverse of what ive said)...
If you have 2 sound cards, select the 3rd box and one channel comes out of the line out of each sound card...
Now that ur mixing with your mixer, you need to record your set, using the 'record line out' on your mixer, plug that into the 'LINE IN' on da sound card.. then use a proggy like Windows Sound recorder (I use creative recorder) and record off the line in......
I hope this helps you in ur quest,
.::DJ Plasma::.
