Topic: Mp3 Skipping Problems in Atomix 1.12
I've been using atomix for about 8 months now, and only recently have I been experiencing skipping going on while mixing in the program. I am a registered user and at first i attributed this to possible corruption within the mp3 files I was using, but after testing this on a couple different machines (ones that I used to run atomix on just fine) in addition to mp3s that used to work just fine, this does not happen to be the case as the skipping still exists. I first noticed this after using v1.12 on my laptop after I upgraded to windows xp. I thought the fact that i was using winxp might also be why this is happening but after going back to win2k it still is occuring, which makes mixing almost impossible.
Has anyone else been experiencing this? and if so what did you do to fix this.?
-Noah
geposted Tue 06 Nov 01 @ 10:52 pm
Edit your AtomixMP3 shortcut and set it to Win98 or Win95 compatibility mode... or set it to "run in 256 colors"
also, you can turn the master tempo off
geposted Wed 07 Nov 01 @ 12:20 am
