OK, is there anybody on earth who uses atomix with some dsp plugins from winamp ?
Or could we safely remove this old feature out from atomix 2.0 (Atomix 2.0 has its own effect plugins, with a full SDK to write your own beat-aware effects).
For the dev team,
Stephane C.
For the dev team,
Stephane C.
geposted Sat 17 Nov 01 @ 7:37 pm
fine by me .. only ones i ever used crashed the puter!!
while yer at it tho, can u add echo and reverb effects to the prog - cheers =)
geposted Sat 17 Nov 01 @ 7:48 pm
Many winamp dsp plugins don't work very well under Atomix, and when they work the time latency is too important. I think we should remove this feature.
geposted Sat 17 Nov 01 @ 7:54 pm
I tried a couple of the plug-ins, found them to be un-useable. I can't think of one good reason that Atomix needs to be compatible with these plug-ins even as it stands now. With the planned improvements of the next version, they become even less important. Remove this feature, especially if it'll help the release come out sooner.
geposted Sat 17 Nov 01 @ 9:32 pm
yeah remove that and add these native plugins:
full screen sensivity adjustable strobe effect
output bpm as midi clock
beat counting / adjusting by tapping a key or from incoming midi clock (to sync songs with external sequencers, beat counters etc)
bpm locked but divideable or manual delay, echo, cut etc effect (like in pioneer mixer maybe?)
geposted Sun 18 Nov 01 @ 10:25 am
Never used it before, never going to use it in the future ! Go ahead !!! ;)
geposted Sun 18 Nov 01 @ 1:15 pm
What's this talk of Atomixmp3 V.2.0?? I thought the next release was 1.2 but I see that the 'news' page mentions the upcoming release of 2.0 and now Mr. Clavel talks of version 2.0. What's happening?
The Atomix Team said a long time ago that all 1.* releases would be free upgrades for existing users, but that version 2.* would have to be bought by everyone and would not be a free upgrade as it would be very different to the current versions and would be like a separate program to Atomix 1.*...
So let's hear it then, is 1.2 going to be called 2.0? All these effects being talked about, were they added after the beta release from Ejay?
geposted Sun 18 Nov 01 @ 2:43 pm
The version 2.0 will be free for registered users.
geposted Sun 18 Nov 01 @ 3:38 pm
Take the support for WinAmp DSPs out.
The SDK will be much more powerfull (will require a bit more creativity though ;-))
Also, I guess it would remove a potential risk of being later than expected ;-)
Rgds,
DJ Corpse
geposted Sun 18 Nov 01 @ 4:08 pm
Aside from DFX which is a sound enhancing plug-in...the rest of winamps plugs are pretty much useless. Latency is too horendous. (sp?)
The Goner
P.S. Ver 2.0? What happened to 1.2?
The Goner
geposted Sun 18 Nov 01 @ 7:07 pm
1.2 was changed into 2.0, but it is still the same product.
Does this SDK allow coders to implement a loop function ? :-) Or is there already such a plug-in on its way ?
geposted Mon 19 Nov 01 @ 2:19 pm
v2.0 already includes a native auto-loop feature.
Stephane C.
Stephane C.
geposted Mon 19 Nov 01 @ 5:56 pm
yay for native looping :)
all the plugins i tried either crashed or had shocking latency... i say ditch them!
al
al
geposted Mon 19 Nov 01 @ 11:02 pm
ok, it's too late now if you wanted to say keep them, because I just removed it and deleted the source code.
Stephane C.
Stephane C.
geposted Tue 20 Nov 01 @ 4:35 am
hmmm shoutcast plugin says all ;)
geposted Thu 29 Nov 01 @ 1:07 am
btw what programmer deletes its sourcecode?? that's just... well never mind ;)
geposted Thu 29 Nov 01 @ 1:09 am
