Topic: XP and fortissimo?
Anybody out there using a maxi fortissimo with XP?
geposted Thu 27 Dec 01 @ 6:50 pm
Yan-XPRO InfinityHonorary memberMember since 2003
I have a maxi sound fortissimo under windows xp.
Think about downloading the lastest drivers available on Intrnet (www.guillemot.com if my memory is good)
geposted Thu 27 Dec 01 @ 7:52 pm
alreaHome userMember since 2003
However, you cannot use the fortissimo as a 3D soundcard under XP. Even whith the last drivers.
Enjoy it, Adrien.
geposted Thu 27 Dec 01 @ 8:49 pm
sketchPRO InfinityMember since 2003
Thanks mate thats just the answer I needed.......
suppose its got to be a sb? Anybody recomend a good one, not to expensive, that will work?
Dan
geposted Fri 28 Dec 01 @ 9:29 am
The sb live works perfectly whith Atomix. Under Win2k, it can be useed as a real 3D soundcard! It should be the same under Xp.
Hope it helps, Adrien
geposted Fri 28 Dec 01 @ 9:47 am
mamaPRO InfinityMember since 2003
And after the Audigy release, the SB Live! is really cheap! :-)
geposted Fri 28 Dec 01 @ 12:54 pm
I'm using an SB Live! 1024 under Windoze XP and it works perfectly, I can monitor using the rear output in Atomixmp3 without a glitch, and it is reasonably priced.
geposted Fri 28 Dec 01 @ 1:33 pm
Sblve is the best!!!I have a sb value and it works perfectly...
geposted Fri 28 Dec 01 @ 3:59 pm
sb live sux.
when u use the 3d channels this happens:
- the volume is way to low .. (for the meters on a mixer)
- the sound quality is terrible compared to dual soudcards
- on one of the channel the left volume is slightly to high, and on the other the right is to high.
dual sb live = ok :p (two soundcards)
geposted Sat 29 Dec 01 @ 1:45 pm
Sorted it, using a AWE32 with the fortissimo and it works perfectly. I tried at first to use another PCI card and when you pressed magic button on atomix it go straight out of sync on one channel. Like it was dragging. The AWE32 will do fine for the mo though.
Dan
geposted Sat 29 Dec 01 @ 7:21 pm
I am using the Hercules Fortissimo II & Maxisound on Windows XP. No probs:)
geposted Tue 01 Jan 02 @ 4:43 am
