Bonjour.
i just got a berhinger mixer which i hooked up to atomix, This mixer doesn't have a seperate eq for each channel (but there is a master EQ), i bought this particular mixer so i can change the levels in atomix, well at least i thought i could.
But I just realized you can't be in soft mode when using external mixers.
Is there anything i can do about this?
Is is possible that the atomix team could code it (or are presently working on it) so the EQ can be enabled in the hardware?
If you could help me that'd be great S.V.P
dave.
dave.
geposted Wed 09 Jan 02 @ 8:11 am
(Cont'd)
I thought i'd able to do it in master/headphone mode....just put the master output from my sound card into the ch1 on my mixer and put the monitor out into ch2 and put the crossfader on the opposite side of the active desk.
Well that does work but i can't adjust the eq in the headphone channel.
Always read the fine print.
geposted Wed 09 Jan 02 @ 8:23 am
Just wait for the next upgrape ; I think it will be possible to use soft mode with a mixer.
geposted Wed 09 Jan 02 @ 10:21 am
