Ok, in the last version all you had to do was make the levels equal by moving the slider. In the new version, no matter how much I move the slider, the levels don't change! The only way to change it is to change the gain.
That is fine, but if the level sliders aren't equal, the songs still won't be at the same level. Is there an easy way to make them equal???
geposted Wed 09 Jan 02 @ 5:18 pm
You can change the level of all your mp3s with a batch program.
Greetz, ikke
Greetz, ikke
geposted Wed 09 Jan 02 @ 5:51 pm
In the options menu just enable auto gain ... and all your levels are equal ... :-)
It's not as good as a dynamics proccesor (hint! hint! ;-)) but it will do just fine ...
Greetz, Dj T-Bone
Greetz, Dj T-Bone
geposted Wed 09 Jan 02 @ 6:17 pm
enable auto gain man but in my opinion u have to reshape ur mp3z
geposted Sun 27 Jan 02 @ 9:45 pm
