I desperately need Atomixmp3 to play cds. I can't get the cda2wav plugin for winamp to work with automixmp3 even when I put in the atomixmp3 folder, and the winamp plugin and regular folder. I need it to play the songs right off the cd, I don't have the patience to rip songs, and ripping will slow down my computer while I'm djing, and cause skipping. What should I do? Doyou have any advice on how to do this?
geposted Fri 11 Jan 02 @ 7:01 pm
You have three choices:
A. Grow some patience.
B. Rip songs overnight while you sleep.
C. Put the alternate CDFS.vxd into the RIGHT FOLDER....which would be rootwindowsiosubsys.
The Goner
The Goner
geposted Fri 11 Jan 02 @ 7:56 pm
that directory didnt show up right... it should be
c: windows iosubsys
where c: is your windows drive
c: windows iosubsys
geposted Fri 11 Jan 02 @ 7:58 pm
I'll try that when I get home. Thanks for your help. I can't rip the songs overnight since I need to be able to play cds that people give me at gigs.
geposted Fri 11 Jan 02 @ 11:33 pm
The Alternate CDFS.VXD is a replacement for the existing Win9x CDFS.VXD driver which is able to show Audio CD's as WAV files with different qualities! It ONLY works for Win9x!
Rename the "old" C:/Windows/System/IOSubSys/CDFS.VXD to CDFS.old and copy the alternate CDFS.VXD to the same directory. Reboot the PC to activate the driver.
Adrien
Adrien
geposted Sat 12 Jan 02 @ 12:01 am
