Anyone Tried ?
geposted Tue 22 Jan 02 @ 8:21 am
Not for the moment.
Adrien
PS take a look at http://www.atomixmp3.com/forum/display.html?forum=9&topic=3016 (it is in french, a may translate it)
Adrien
geposted Tue 22 Jan 02 @ 9:20 am
You can try to use WineX???
Greetz, ikke
Greetz, ikke
geposted Tue 22 Jan 02 @ 4:59 pm
Wine is the windows emulator under linux.
Adrien
Adrien
geposted Tue 22 Jan 02 @ 8:46 pm
While Wine (http://www.winehq.com/) does a reasonably good job on simple programs, I doubt whether it's quite up to running Atomix in a fast, reliable manner. When you need all the CPU power you can get, dedicated to the task of decoding MP3's, running under an 'emulator' is not going to help the cause any. If you really must run Linux for this purpose, then a dedicated Linux application is really the only way to go.
Cheers...
Swift
Cheers...
Swift
geposted Tue 22 Jan 02 @ 11:08 pm
