Topic: recording programs
can some 1 give me a site were i can found a program that will let me record what i do in atomix (hardmode not soft) without having to mess about linkin things up.
e.g a program that records wots coming out of my speakers
cheers
geposted Wed 30 Jan 02 @ 7:59 pm
First of all: taht's not possible when you use a mixer (if you don't want to use a line-out line-in connection)!!! To record what you're doing: use e.g. the standard Wave Recorder (if u use win 95/98). You also can use CoolEdit (www.cooledit.com) or Goldwave or another wave editor/recorder. If you want to save your mixes in mp3 format, use one of the last progs I told you about.
There's also a program called "Totalrecorder" which does this job, but I can't tell you if it works, because I never used it.
Greetz, ikke
Ops! In hardware mode, you must connect your "rec out" either in the mixer, or in the amplifier,and your "line in" audio cardwith a jack/2 rca...
