brand new egosys wamibox multiout soundcard
powered via the pcmcia slot so no extra power supply needed
gives you 2 seperate sets of stereo outputs on gold tipped rca jacks so you can go into an external mixer
also it has digital and optical outputs for those of you with ADATS and other advanced gear.
this box also has mic and heaphone jacks, plus midi in and out
its really a whole studio in a box, supports WDM, direct X, AISO and also MME drivers so it will work with whatever software you throw at it
I use them as multiout direct x outputs for atomix into an external mixer and also with the AISO driver unde cubase and the midi i/o i run softsynths and have them playable in realtime due to the low latency
only $300 for this unit
reply to Infader1@hotmail.com
feel free to check out my feedback under "lqdsnddist" on ebay
geposted Fri 01 Feb 02 @ 7:13 am
