Hey guys !
I use soft mode only for recording, along with using my headphones to monitor. I don't want to rely on atomix's auto-gain feature since it is not that accurate.
IS there any way to accurately match the output levels using the headphones? (Too bad the headphone output went through the sound card AFTER the input fader - if u know what i mean).
Or should i just use a normalization program. Does anyone know any good ones ???!!!
Cheers !!!!!!
Dave.
Cheers !!!!!!
Dave.
geposted Wed 06 Feb 02 @ 5:15 am
uhh?
geposted Wed 06 Feb 02 @ 6:13 am
Like DJ Maboul said in the French forum: dbPowerAmp is a good tool for that. http://www.dbpoweramp.com/
Greetz, ikke
PS. Sorry for those effects, I didn't recieve anything from Corpse. I hope he'll help me a.s.a.p. I'm going to make a sort of tutorial (using a new .h file) so Java programmers (like you) can create DSP effects quite easy.
Greetz, ikke
geposted Wed 06 Feb 02 @ 1:02 pm
i've tried db power amp, it sucked!!! I couldn't notice any normalization and i've compared 40 "normalized" tracks with the originals and it's just the same... And it's not that the originals were already perfectly normalized, because some tracks were really very low volume...
Any other ideas??
Any other ideas??
geposted Thu 07 Feb 02 @ 12:19 am
YEAH !!! I tried it too.....NOTHING !!!
But i still want to check the output level using my headphones.
Cheers.
Cheers.
geposted Thu 07 Feb 02 @ 3:03 am
Try MP3 Workshop. You can increase or decrease the sound level of your mp3's.
http://myhome.iolfree.ie/~mp3workshop/
D.
D.
geposted Fri 08 Feb 02 @ 3:24 pm
Try mp3 gain (www.geocities.com/mp3gain)
geposted Sat 09 Feb 02 @ 2:19 pm
Regarding normalisation, some programs normalise an mp3 by finding the peak volume and using that level as a standard for other mp3s. Other programs such as mp3 gain and mp3 workshop normalise an mp3 by finding the average volume which is far more accurate. Perhaps dbpoweramp uses the former method (having never used it, I cannot say this with certainty).
Mike
Mike
geposted Fri 15 Feb 02 @ 3:11 am
Hey! dadegian I did tried that program (MP3 Gainer) and its perfect. The only problem is the program takes too long to analyze the files, but ones U pass that. U will it worth it.
geposted Fri 15 Feb 02 @ 5:00 am
