Topic: How to cut tracks when recording?
I was wondering what program do you need to use when you do a full mix to burn on cd but want to beable to give each track a number so when you play the cd its not just a 1 track mix and you can choose which song you want to play?Thanks
geposted Fri 08 Feb 02 @ 7:59 pm
This feature is already included in Atomix 2.0. When you are recording, you can use the cisors next to the record button to cut your file, or choose to let Atomix do it automatically. In this case, the file is cut each time the crossfader reaches one of its ends.
If you want to cut a wave or MP3 that is already finished, you could use something like Aoustica's MP3 Audio Mix. Just load in the wave or MP3 and set trackmarkers for exporting them to single separate waves.
