I have a whole bunch of dsp effects written .... and they are all saved as .cpp. How do i compile those to .dll's ? I am desperate to try them out ! The more you can help me... the sooner they'll posted on the effects page !
Thanks for your help guys!
geposted Sun 17 Feb 02 @ 6:37 pm
You also wrote some plugins? Or are you speaking about the source codes I made and mailed to you?
For those who are interested: it's a noise gate, a compressor and a vocal remover (I made). I just hace some problems to compile them. If someone can help me out... I use the Borland Free Command Line Tools 5.5.1 DOS Prompt rules!!!
I'm also working on a vocoder.
Greetz, ikke
Greetz, ikke
geposted Mon 18 Feb 02 @ 6:04 pm
Yes Ikke .... i'm talking about yours ! Don't worry, I am not going to take credit for them ! (I'm the one testing them out ... not writing them)
geposted Mon 18 Feb 02 @ 8:06 pm
What about a "bass kill" plugin/dsp effect??
geposted Mon 18 Feb 02 @ 8:19 pm
Should be possible. I'll try to write one (I don't promisse anything!) when my vocoder is ready.
geposted Mon 18 Feb 02 @ 9:29 pm
You know you can also use the bass kill shortcut key ?
geposted Mon 18 Feb 02 @ 9:45 pm
Or right click on the bass EQ knob
geposted Mon 18 Feb 02 @ 9:46 pm
