Topic: about this program...
Is there a way i can make scratch effects, like a turntable with atomix? If there isnt, can anybody recommend a program where I can alter music by adding effects and scratching. Thanks alot.
geposted Wed 20 Feb 02 @ 2:15 am
At this time, I haven't found any good turntable scratching programs. I would get samples off the web, or if you're really desperate, make scratching noises into a microphone connected to the line in on your soundcard. Jk. Try looking for scratching samples, that you can put in the samples deck in atomixmp3.
-MixMasterMatt
I know, I'm a beta tester...
