Topic: Recording Through Line-In Jack .....
What programs do you guys use to record from your external mixer using the line-in jack on your sound card ? I am using supermp3 recorder .... and the quality is quite exact as the original !
Any other possible solutions ? (Besides using atomix to record?)
Thanks !
geposted Sat 23 Mar 02 @ 6:25 am
I don´t know how often i have said this:
I think the best prog to record music in mp3
with a (very good) quality you can decide (128 kb- 320kb or hoq much you want...) is: Music Match download it on musicmatch.com
YOU DON´T NEED A PC WITH A MEGA POWER !!!
with this prog i record often from radion too.
dj BluFF
i use winamp, with shoutcast and streamripper, not so easy to setup but you can do a lot other stuff with the setup too.
Try This One is basically a studio app but it's gr8
Sound Forge.By Sonic Foundry.It's got almost all the function
MusicMatch is good for record from line in also
You can record it straight to mp3 format if you want to
G'luck
I've used cool edit in the past for line in recording.
sorry .. i meant the quality is NOT as great as the supermp3recorder !
