Topic: Recording WAV files
I have ver 2.1 When I record for example 5 tracks they all sound ok while recoding. They mix to gether well, the only problem is when I play back the 5 WAVs there is a slight gap between each track and thus ruins the mixing!!!!! any ideas?
geposted Sun 31 Mar 02 @ 3:57 pm
If you record continously you should end up with only one large wave file ? are you saying you end up with five ?
STU
The problem is with the program you use to listen to the files...
I have the same problem with mediaplayer (ducks for cover), it leaves a gap of 5 seconds between songs that are mixed on a cd...
Solution:
get winamp 3 BETA 2! ;)
no problems anymore
(or u could use another program, like...???)
Hi Stu
Yes it creates 5 individual WAV files!!!! how do I make one WAV file?
Sorted my issue and now all works fine.
