Topic: just a couple of questions bout 2.1
what is the charts-option?
what is the counter for? time-thingy? just for finding out how fast you can dirk a beer or what? what's the use? jsut wondering...
some time ago it was asked fo a maual beatcounter? is it present in 2.1`?
:+: dj vishnu :+:
geposted Sun 31 Mar 02 @ 6:02 pm
When the charts option is on, Atomix sends the name of each file you play to the Internet server, and then a chart is displayed of the songs that are played most often.
The counter is used for example to calculate the time between the beginning of a song and the moment when the melody begins, so you know when to launch the song.
geposted Sun 31 Mar 02 @ 9:03 pm
so atomix is spyware now? what else does it send?
where do i find this chart?
geposted Sun 31 Mar 02 @ 10:55 pm
Yan-XPRO InfinityHonorary memberMember since 2003
No atomixmp3 is not a spyware.
Atomix Productions doesn't receive any informations about your identity, your computer or even other softwares, websites you are surfing on, or hardware you are using.
Atomix Productions just check the version of Atomixmp3 you are using.
By the way we don't store in any database the records of this process. Atomx productions just want to be sure that you're using a legal version of the software.
geposted Mon 01 Apr 02 @ 2:08 pm
