Topic: EDITING MIXED FILE
djdobPRO InfinityMember since 2003
I need help... ATOMIX save the file as a WAV, now .. what should I do if I have a 60 minutes mix and I want to divide it into diferent tracks before I burn it. The reason is that if I burn it as it is I had to listen to the whole file and I can't skip songs when I play it in a CD PLAYER cause it's a single file. Do u guys know a CD Burner that can do that trick ???
by the way .. scuse my english.
geposted Sun 07 Apr 02 @ 12:08 am
if you have version 2 or 2.1, it should enable you to cut the tracks as you record your mix.
go to the record window and you should see scissors, that button does the cutting.
geposted Sun 07 Apr 02 @ 2:28 am
shut .. I don't see that option in the recording window :(
geposted Sun 07 Apr 02 @ 2:44 am
:) I found it ... Autocut : Enable .. thank you .. now I have NERO 5.5 .. should I set the time between each track to 1 second ? .. because I don't want pauses on the CD, I want the full mix with the option of search for the tracks .
geposted Sun 07 Apr 02 @ 2:57 am
If I wanted no pause whatsoever between track I'd set 0(zero) seconds.. but maybe that's just me? :)
*no intention of being a sarcy smart-ass, just couldn't resist*
geposted Sun 07 Apr 02 @ 12:31 pm
Tell the program to burn disc at once and there will be no gaps between the songs.
geposted Sun 07 Apr 02 @ 3:29 pm
Thank you for u guys help ... ;)
geposted Sun 07 Apr 02 @ 6:55 pm
