i have a new lobtop
pemtiun 4 (1.6)
512 ram
yamaha ac-xg wdm
and it should work really good
but there are sometimes
that the music skips
i do not understand
i have a sonystyle vaio pcg-grx550
do you thing is the lobtop
or the program
"""""i love atomixmp3""""""""""
but i am scare to use ..live... if it does skip ones or twis a nigth
pliz tell me what you thing
pemtiun 4 (1.6)
512 ram
yamaha ac-xg wdm
i do not understand
or the program
geposted Thu 11 Apr 02 @ 7:21 pm
put into hardware mode or use lower bitrate mp3s e.g 128kbps
geposted Thu 11 Apr 02 @ 8:21 pm
how do you put it in hardware mode in 2.1
geposted Sat 13 Apr 02 @ 10:23 pm
U can't run 2.1 in hardware mode.
What OS are u using?
Try to update sound card drivers!
Good luck
Peroz
Good luck
Peroz
geposted Sun 14 Apr 02 @ 11:12 am
disable the time scratch in the option menu
geposted Mon 15 Apr 02 @ 11:57 pm
