i got one sound card in ma computer so i bought the "stereo channel splitter" It allows you to set up two distinct output channels. One channel goes to the speakers, and the other, to your headphones for monitoring purposes.
I don't know how to make it work with AtomixMp3 though...does anyone know???
geposted Mon 06 May 02 @ 8:23 am
In order to use that feature you need the full version of AtomixMP3 and then you can change the sound configuration in the options-screen and change it to the apropriate setting (one soundcard, headphones+speaker)
geposted Mon 06 May 02 @ 9:13 am
