Topic: And.... whats is the best sound card ??
(nt = no text)
geposted Fri 24 May 02 @ 7:11 am
vlk72Home userMember since 2002
geposted Fri 24 May 02 @ 11:00 am
Terratec in pro version: not cheap at all! But the result is great!
geposted Fri 24 May 02 @ 12:51 pm
GrimmPRO InfinityMember since 2003
Terratec 6-Fire DMX. Best 24/96 6 channel consumer card available.
Audigy is crap compared to Terratec. Its not even true 24/96, and still upsamples all audio to 48KHz badly. It can't record in 24 bits, or for that matter at 96KHz, and it cant even play back 24bit, 96Khz files. The only thing it can do is *pass through* a 24/96 digital stream from you DVD drive to an external decoder.
geposted Sat 25 May 02 @ 4:46 pm
Thanks !!
geposted Mon 27 May 02 @ 2:48 am
how much?
geposted Mon 27 May 02 @ 8:59 am
geposted Mon 27 May 02 @ 1:43 pm
I'm DJ and I want a seconde line out to listen to the music before put it in my mixe
geposted Mon 27 May 02 @ 5:41 pm
A sound card with 3d fonction. For ex., you may use a SB live/value/extigy (or the terratec 24/36, the best sound card, sûre!)
With trial, it's not possible. With trial + crack, it's not possible, too :))
geposted Mon 27 May 02 @ 11:08 pm
