Topic: Startup Control Panel - w2000/wXP
Because the 'msconfig' command doesn't exist in the w2000/wXP and if you're tired that more and more programs run at system startup, there is a prg: Startup Control Panel! Easy to use, try it :))
http://www.pcworld.com/downloads/file_description/0,fid,7976,00.asp
Atomix is the best (with TMoP)
geposted Sat 06 Jul 02 @ 9:47 pm
msconfig does exist in xp
geposted Sat 06 Jul 02 @ 11:42 pm
Ok, thanks, I didn't see it... ;) In fact, I didn't try it, I was sure that the command didn't exist in wXP! Msconfig command doesn't exist with w2000, no?
With Startup control, it's possible to disable the startup common files (in Hkey_local_machine) and the files in Hkey_current_users. So, more startup files are avaible there than in msconfig.
geposted Sun 07 Jul 02 @ 10:11 am
