Topic: Where can i find remixing software?
Can nebody help me? i want to know where i can find and download music remixing software! what is it called???
please help me asap
geposted Tue 20 Aug 02 @ 12:19 pm
Firstly, i doubt there is any software specifically designed for remxing and secondly, if you explain your problem in more detail, then there is a better chance that people will reply
Tek2K2
you can go for reason 2.0 propellerhead.com
you can go for acid pro 3.0 and sound forge 6.0 from www.sonicfoundry.com
and cubase vst
you can go for the ejay collection www.ejay.com
theres orion pro
NaDeR
Cool Edit Pro with the mp3 add on.
I use WaveLab and SoundForge 6.0 for sound editing and I use Acid Pro 3.0 to create loops for making remixes. When you use them all together and actually know what you are doing, making a remixed song takes no time. But if you want to buy these programs look at spending some big cash. I think Acid Pro 3.0 goes for about $350 or around there and SoundForge cost about $300. WaveLab I got free but I think it is expensive also.
pcdj producer.....
f
PCDJ Producer is a new one on the block - but it looks very powerful. It's less than UK£40 too! www.emissionuk.com
remix=Cubase Vst or sx
Sonic Foundry Acid PRO 4.0 is out now !!! Great piece of software ... it just takes plenty of time to figure it out !
there is a lot of mix software easy and powerfull.
www.sonicspot.com/dj.html
or
www.sonicspot.com
try it
Fruity Loops is another one. I am trying to figure it out right now. I also have Sound Forge and am trying to figure that one out as well. Hopefully I will figure out soon and make my own tracks. If anyone has knowledge on these programs please email me with some suggestions. Rabicem733@aol.com
thanx.......DJ Marcola
FRUITY LOOPS ROCKS
Anything from eJay sucks the big one. By mistake, I bought two copies of eJay. And I am not using either one.
