Forum: Wishes and new features
Topic: ID3 Support
Hi all
I would love to have ID3 support in Atomix. Since I have literally thousands of MP3 but not a consistent way of naming them. They are usually named "track# - title", but sometimes are "author - title" or even weirder things like "track# - author - title"... Also, some authors have got scores ( - ) in their names, making the software even harder to use.
On the other hand, I have most of my MP3s with ID3 tags set up so... ;)
I suppose this should be done in a 'selectable' way for people who are comfortable with the way it works now (well, this is too obvious)
Thanks and keep up the good job
DJMantenido
geposted Wed 21 Feb 01 @ 12:38 pm
It is too slow when you have thousand of mp3 to add in the list! Sorry!
True, but could you also not make that an option so you can run/do that before starting your mix? Like have a "Make ID3" button that would load in the ID3 tags? This way you could click if you want, let it run for a while, then you would be ready. Just a possible compromise.
_______________________________
The Mechanical Ruins
DJ |/|ech
http://www.mp3.com/DJMech
Just rename the mp3 you've just downloaded ;-)
If you still read this: you can import all your files in RealJukebox, which reads your ID3 tags, and then (in the options box) set the names as author - title.mp3, and click on "apply on existing files".
Greetz, ikke
