I just realized a REALLY important feature I'd like to have in a future version of Atomix. A DATABASE file! No, its not what your thinking (maybe ;).
I went to edit/update some titles and ID3 tags of my mp3s that I use alot in Atomix. Low and behold, Atomix forgot what the BPM, dB level, and cues point of all those songs I fiddled around with. ARGH!!!!!!!!!!!!
I figure that all that info is written to at the end of the actual mp3 file, and any fiddling results in that information being over written. But its a HUGE pain having to run dozens od mp3 files through Atomix again just to get the dB and bpm of the songs, not to mention set the cue point again.
What Atomix needs is a database to keep track of all that information. So if the mp3 file is changed in a minor way (ID3 information for example), Atomix wont go geezer on the file and "forget" all the settings for it. ;)
geposted Mon 23 Apr 01 @ 6:15 am
          i wish it also store fullpath+filename of the songs it played to text file or something where to grab them later on if u can't remember later on what song you mixed..
    geposted Sat 19 May 01 @ 2:00 pm
          Sir all the informations are already saved in a database file and not at the end of each file!
You need to backup there files regulary.
the files are:
Atomixmp3 internal database
Mp3 database.txt
the files are:
Mp3 database.txt
geposted Sat 19 May 01 @ 7:24 pm
