Forum: Wishes and new features
Topic: Add an Equalizer
A 3 pot equalizer for each channel whould be nice ala DiscoNova.
Even better, after the EQ is set, save it for future plays.
geposted Fri 24 Aug 01 @ 3:58 am
Just you wait.
What do you mean? Is there still one and I really do not see?
Would be great, that is a tool everybody needs, so?
Connor
An equalizer is planned within the next version, which will be released in a few weeks.
Will the next version fix the bug in automix (cut's songs short)?
It's not a bug. Atomix tries to detect the moment when the bass line stops to perform a better beat matching. That's why it often cut the end of a song. There is no way to disable this feature yet.
I don't think every song drops it's base line 40 sec before end. Even if it did, it's still a bug when all the songs get cut off.
i dont have that prob... I second the motion on the EQ but also add a checkbox er sumthin under each slide (er however your planning on doing it) to completely cut a channel...
Thats called a kill switch. I want to see a bass kill button more than anything...
I think maybe even a check box or something that when check will inversely effect that band on the other decks EQ. This way you can free an extra hand so you a automatically fade up the bass (or mid, treble etc) whilst fading down the bass (etc.) even when you crossfading (with the mouse). I guess if the both EQ's where keyboard controlable then you probably wouldn't need this feature as much?
