The possibility to read CD Audio
geposted Fri 07 Sep 01 @ 4:33 pm
that would be perfect it read cd audio
geposted Sat 22 Sep 01 @ 8:24 pm
OK, DJ Gérald (French Forum) has found the WinAmp plug-in to which I referred in an earlier post on this Forum.
Apparently it allows to read CD Audio disks from within Atomix providing your CD-Reader is rapid enough at audio extraction and has sufficient buffer memory.
Give it a go (I'll try it out in the next few moments).
DJ Corpse
DJ Corpse
geposted Mon 24 Sep 01 @ 8:45 pm
Ooops,
The URL reffered to by DJ Gérald is
http://www.winamp.com/components/download_component.jhtml?filename=http%3A%2F%2Fftp.winamp.com%2Fcustomize%2Fcomponent%2F2000%2F4%2F14%2FP%2Fcda2wav.exe&componentid=12943
Rgds,
DJ Corpse
Rgds,
DJ Corpse
And it bloody works !
Download - Run - Shutdown&Restart and you're in business.
When exploring the CD you"ll find 2 directories on the Aduio CD named "mono" and "stereo"
You'll find following menu tree:
"mono"
"8 bit"
"11025"
"22050"
"44100"
"16 bit"
"11025"
"22050"
"44100"
"stereo"
"8 bit"
"11025"
"22050"
"44100"
"16 bit"
"11025"
"22050"
"44100"
Just select the audio quality as you desire (best quality is found in stereo/16bit/44100)
Playing & Mixing a track from CD with another one on the HD appears to work fine.
A quick test while playing two tracks off two seperate CD-readers simultaneously wasn't entirely satisfying in terms of sound quality (started skipping and stuttering).
Rgds,
DJ Corpse
"mono"
"8 bit"
"11025"
"22050"
"44100"
"16 bit"
"11025"
"22050"
"44100"
"stereo"
"8 bit"
"11025"
"22050"
"44100"
"16 bit"
"11025"
"22050"
"44100"
Rgds,
DJ Corpse
geposted Mon 24 Sep 01 @ 9:06 pm
