Fix the pitch...so that it will not couse the bass to fuck up
geposted Wed 26 Sep 01 @ 12:25 am
I don't have any issue with the pitch affecting the bass.
So I guess it might be wise to look further than simply blaming Atomix for that.
By the way, make sure to disable the Master Tempo feature to get the best sound quality.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Wed 26 Sep 01 @ 10:24 pm
We have already improved the quality in the next version
geposted Wed 26 Sep 01 @ 10:50 pm
I use the pitch control a lot! And I use the master tempo feature. Never had even a passing problem with sound quality.
Rick
Rick
geposted Thu 27 Sep 01 @ 4:17 pm
when playing a tune on +/- 0 everything works fine, but when i use the pitch it cuts out some parts of the sound. generally it isnt audiable, but on some bass kicks it turns the sound into a real shitty kick... i would be fine with the option to turn on the normal LP pitch like: pitch up - song faster AND higher... fine with me, and i think it would solve the problem too... in other words: please give us the option to choose... :o)
thanx
niri
thanx
niri
geposted Fri 28 Sep 01 @ 7:36 pm
Try to disable "master tempo" and it should work!
geposted Fri 28 Sep 01 @ 8:03 pm
i have just found the option myself ;)) sorry...
thank you guys... keep it up!! :o)
geposted Fri 28 Sep 01 @ 8:19 pm
make a 12% and 12% pitch [some 137bpm tunes into 145bpm]
and a 50% and 50% [for happy hardcore music]
geposted Mon 26 Nov 01 @ 2:05 am
