Greetings,
Nice job on the effects subsystem! I love it!
(btw, the "long flanger" is a great plugin!)
Anyhow... Regarding effects. The effects are simply on/off... Yes, they sound great, but its hard to fade them in and out.
When I use the hardware flanger on my SB Live!, I have the ability to fade it in and out. I can select the 'percentage' of the effect, allowing me to bring the effect in and out of the mix seamlessly, and if done right, it's hard to tell when the effect really went away (ahhh.. the art of mixing!)
What would be good, is a simple effects level control, a slider, that will control the level of the effect compared to the original sound.
Anyhow, above all, 2.0 is a KILLER upgrade, the more I use it, the more I love it, and MANY THANKS for the hard work.
geposted Wed 05 Dec 01 @ 8:04 am
I've been getting good at timing the right part of a song to start a flange at.
I've also noticed that holding right-click for like a second on the standard flange, releasing, and doing it again and again (with the beat) makes a cool effect, tho its time consuming :d
geposted Sat 08 Dec 01 @ 2:22 am
