Forum: Wishes and new features
Topic: A default volumen for effects!
Every time I use atomix I´ve to change it!
geposted Sat 22 Dec 01 @ 11:44 pm
DJ Coc,
I suppose you refer to the volume of the samples, not the effects.
Rgds,
DJ Corpse
Yes, i made a mistake! I refered to the samples!
Thanks!
There is existing software to bring a lot of mp3's in batch at the same level. Maybe you can look at one of these?
Greetz, ikke
You can use "DBPowerAmp Music Converter" (http://admin.dbpoweramp.com/dmc.htm)
It has Explorer Shell integration and allows you to normalize MP3 by a simple right-Click.
It's a very fine Software.
