Is it possible to release the patch of this feature? It's really necessary key shortcut if you are not using an external mixer.
geposted Tue 25 Dec 01 @ 4:46 pm
you can bind all functions to keys. also kill! look at shortcuts and you will find. it is not bind as standard
Desruptor
Desruptor
geposted Tue 25 Dec 01 @ 8:09 pm
I know than I can add normal and kill shorcuts, but I would like to get a shortcut for example: bass up, bass down. Do You Know, what do I mean?
geposted Tue 25 Dec 01 @ 9:48 pm
get external midi controller with knobs& sliders (they are about 200$ and up)
then just complain enough here for the midi support.
geposted Wed 26 Dec 01 @ 5:26 am
Mmm, it's quite difficult to put a midi keyboard in a small DJ boot...
Otherwise, midi support would be great! (e.g. xith the Roland DJ2000 mixer!!!)
Greetz, ikke
Greetz, ikke
geposted Wed 26 Dec 01 @ 12:55 pm
I support the idea of adding keys for adjusting the EQ. I am an experienced DJ and those functions are CRUTIAL, this is the best 3 band EQ i've seen so far and it can be even better....
DJ Emile Kaselowski
DJ Emile Kaselowski
geposted Sat 29 Dec 01 @ 8:31 pm
