I would like to use AtomixMP3 to prerecord a mix for my spinning classes (about 60 min length). The automix works in some cases, but I often have to do the mixing manually.
When I would like to change a song in my mix I have to manually redo the whole thing. It would be great with some sort of script/macro language where I can specify start/stop and mixing parameters (betamatch, autobpm, mix start mix end) for each song.
A new Cue Point to indicate the End of the Mix would be great, I don't like to edit my mp3 just because I only want to play part of the song.
geposted Mon 15 Jul 02 @ 6:34 pm
Appearantly it already exist such a program, it's called Mixmeister. There you have a graphical overview of all your tracks on a timeline and you could adjust all settings in advance.
Once everything looks OK you could play it through the speakers or record it to disk.
The only drawback is that the timestretch implemnetation is not as good as in AtomixMP3.
geposted Thu 18 Jul 02 @ 4:00 pm
