I know this has already been discussed, but I really want to know more about the technical possibilities of a third deck in the next version of atomixmp3, and the topics are placed by posting date/time and not by last post date/time...
BTW, when does the next version come??? And will there be, if possible, a third deck?
I would really like to hear what experienced/vip members think of this idea. I know that a lot of people want it in, so I only want to know about the (technical) possibilities and the advantages/disadvantages.
TIA
TIA
geposted Wed 24 Jul 02 @ 12:59 am
Main problem with this is the amount of processing power to run all three decks together, I would think even the 2g+ processors would struggle at the moment but within a year we will be up to 3g+ and the road widens !!!!!
One day !!! ( A personal opinion only !)
STU
STU
geposted Mon 29 Jul 02 @ 9:17 pm
How is it possible then to use mutiple atomix programs running at the same time????
I've mixed a couple times 3 tracks together that way but it's just too hard to keep the tracks in sync. So I don't see the problem. If you reduce Atomix to it's minimum, leave all the fancy stuff of it and just use 3 decks it should be possible?!?
And what if you minimize the size of the atomix screen so 2 atomix programs fit underneath each other. That would be alot easier to mix 3 tracks together with multiple instance.
Hope I get a response on this one
GnoedeL
Junior Member (forgot to login!)
GnoedeL
geposted Wed 31 Jul 02 @ 12:23 pm
Trouble syncing the three tracks??? really you only have to synce two beacause in one of the atomix windows you can use the beatmatch....if your struggling to beatmatch 2 songs, with all of the controll you have in atomix....soundz like a crappy DJ
geposted Tue 06 Aug 02 @ 1:33 pm
how do you suppose DJ's did it in the dark ages.... I don't remember ever seeing an auto sync button on a turntable..
geposted Tue 06 Aug 02 @ 3:51 pm
I know I am able to mix with 3 decks when I want to, but the problem is that I can't record my mixes when using the multiple instances function... :(
geposted Thu 29 Aug 02 @ 12:03 am
