May be somebody out there might have the solution.
When I try to use the 3D headphones options. The program crashes miserably.
I get the blue screen and the only way to get out of it is rebooting.
Help is appreciated
Help is appreciated
geposted Mon 16 Apr 01 @ 11:57 pm
Yes, I have a solution:
Don´t use a crack, purchase it!
Simple, but it works!!
mama
mama
geposted Tue 17 Apr 01 @ 12:20 am
I'm sorry to tell you mama I'm not using a crack I'm a register user. I reported the bug to Atomix A while back and all I got was thanks for reporting the Bug.
I'm writing this on the forum Hoping somebody out there would have a solution.
Atomix is a great program, That's the reason why I spend my hard earned money on it. I have faith it will develop into something really powerful.
Abel
Abel
geposted Tue 17 Apr 01 @ 3:28 am
So let me say sorry. Please post your specs (OS, CPU, RAM, soundcard, etc.).
mama
mama
geposted Tue 17 Apr 01 @ 7:24 am
Hi mama, thank you.
My setup is: OS win98, 333mhz Intel Celeron, 65 megs RAM, SB live value I downloaded the latest drivers from the site, Direct X 7.0, Video 8megs SIS626.
Using Atomixmp3 1.12.
Thanx in advance
Abel
Thanx in advance
Abel
geposted Tue 17 Apr 01 @ 11:46 pm
First try to deinstall LiveWare (if installed), then reinstall the actual drivers only (be sure to set "4 speakers" while install process) and upgrade directX to version 8. Then please reinstall AtomixMP3 and it should work.
mama
mama
geposted Wed 18 Apr 01 @ 7:57 am
Sis cards don't work properly with DX8, even upgrading to the driver Sis claims DX8 compatibility...
Stay in DX7
Stay in DX7
geposted Fri 20 Apr 01 @ 11:44 pm
My SB Live works fine with DX8!
mama
mama
geposted Sat 21 Apr 01 @ 7:56 am
Thank mama. No, It did not work. I upgraded live ware and direct x to 8.00.
I'll wait for the next version and if I need the monitoring feature, I'll just use a second card.
Everything else works great.
saludos
Abel
saludos
Abel
geposted Sun 22 Apr 01 @ 6:34 pm
The support team has failed you miserably. Bet you're glad you spent $60 on the program now, aren't you.
Case dismissed.
Case dismissed.
geposted Sat 28 Apr 01 @ 4:59 pm
Mine crashed (froze) last night twice. First into the first song then into the 3rd song. It was just a program freeze. After that I went back to my original dj program for the rest of the night and will regroup this week.
I run a AMD k6-2, 500 - 512 ram. Have been runnning strictly computer for over a year with another program.
geposted Sun 29 Apr 01 @ 4:59 pm
Take care to uninstall the trial version before install the full one., and DO NOT play 48KHz song, it isn't support by the 1.12. The first Pb occured whit VDJ, I don' t know if there is still the same Pb with Atom. The second will be resolved with the next version. Alrea.
geposted Sun 29 Apr 01 @ 5:28 pm
