Forum: Old versions
Topic: Program doesn't work on 2 soundcard!
Hi!
I have 2 soundcard and the program doesn't use these cards. And i define evrithing in Sound Config menu but doesn't work any option.
Plesase help me!
ThanX!
DJ Wa[R]eZ
geposted Sat 30 Jun 01 @ 6:22 pm
OyyoDamsPRO InfinityHonorary memberMember since 2003
You must have the full version. If you have the full version please be more specific.
geposted Sat 30 Jun 01 @ 6:36 pm
I Have got the full version and mine also doesnt work with 2 soundcards. I select the "2 Soundcards" Option, select the 2 soundcards and the Speaker/Headphone option, but nothing. It also doesnt work with the mixer setting for the songs to go through the different soundcards.
DJ Renegade
geposted Sun 01 Jul 01 @ 9:28 pm
i have got it to work with 2 sound cards, but when u listen through the head phones the sound signal is realy distorted and the songs are almost unregognisable. the levels are also wrong in that the sound souce for the headphones must be turned right down to here the song without blasting your head off.
geposted Thu 26 Jul 01 @ 12:44 am
