Forum: VirtualDJ Skins
Topic: skins aren´t visible!
If I extract skins in the atomix folder, the don´t appear in the config menu. What can I do to see and change them?
geposted Thu 22 Feb 01 @ 8:57 pm
click on the skin option in the OPTION PANNEL OF ATOMIXMP3.
Then you can normally see this skins if you use atomixmp3 1.12
Make sure that you also extrated the file ini to the Atomixmp3 directory. Example you need Denon.bmp and Denon.ini.
Saludos
Abel
I extracted them completly in the atomix folder (bmp + ini) but I can´t see them in the skins menu. My version is 1.12.
Try un-installing and then re-installing atomix
-= R ! S C =-
Team Atomix
Hy everybody,i have problem with skins.When i download a new skins and install them,every thime when i change skin atomix is turn off.Can anyone tell me why?.I have atomix version 2.0
mladen:
If you have the 2.0 version of atomixmp3 and are trying to use skins that have a higher resolution (1024*768 and above), then that is the problem. V2.0 does only support skins with the resolution 800*600.
But if it is a SVGA-skin (800*600) that your selecting and it still shuts down the program, then try going to the top line of the XML-file of that skin and remove the width and heigth parameters (width="800" height="600") This may allow you to use the new skins, but some of the new features (v2.1) that are included in the skins will not work.
I hope this answers your question...
cheers...
- Jim
Can anyone tell me what version of atomixmp3 is better, 1.12 or 2.0?
By the way Jim Nordic,thanks you helped me:)))
CHEERS
