I just looked at the sample skin's INI-file and saw how easy it is to make skins and I'm eager to make my own.
But I have one question about next version of Atomix. Will there be different setup for skins? By that I mean, different resolution, change in skin-parameters, or new features. I don't want to start designing a new skin, just to find out that the new version of the software has features that would have made me design it differently.
It's only a matter of weeks... So
What are the new features actually? Or is it just a new engine? (If you don't want the public to know before the release, then just tell me and my lips are sealed. I'll act suprised. :) If it should get out and the leak can be traced to me, then you have my permission to sue me for $40.)
Jim the Norwegian
Jim the Norwegian
geposted Thu 05 Apr 01 @ 6:12 pm
You can start designing new skins, but the .inifile is fully dead...
You can begin with 1.12 skins and skip it to the next version after -almost- with no problems.
geposted Thu 05 Apr 01 @ 6:36 pm
May be u can help I just got the new version and I would like 2 know how to save some skins and use them when i down load them.
thanks
thanks
geposted Sat 19 May 01 @ 9:33 am
NEW VERSION??? - where did you get that from???
geposted Sat 19 May 01 @ 2:07 pm
sorry - forgot to log in.
Or do you mean version 1.12 which is the current version, not the NEW one which we are all eagerly awaiting.
geposted Sat 19 May 01 @ 2:10 pm
Exactly when will the next version be released???? 1 week, month
-BC-
-BC-
geposted Wed 13 Jun 01 @ 3:04 am
(nt = no text)
geposted Sun 17 Jun 01 @ 6:03 pm
This is the suxxxxx
geposted Wed 21 Nov 01 @ 11:26 am
geposted Tue 16 Apr 02 @ 9:23 am
