Forum: VirtualDJ Skins
Topic: "Cool" skin
I've just downloaded the "cool" skin from Janosh, is it possible that it's only one file???? What extension do I have to give it??? I've got the 2.1 version of atomix
hope someone can help me
YDC
geposted Wed 24 Apr 02 @ 4:21 pm
The file you downloaded should be a .zip-file that is about 300-400 Kb in size.
In that .zip-archive there's a .bmp and a .xml just as any other skin.
geposted Wed 24 Apr 02 @ 4:29 pm
then there is the problem, I only receive one file
geposted Sat 27 Apr 02 @ 5:50 pm
Yes, one .ZIP-file.. it's an archive-file containing the other files...
Nevermind.. just try downloading it over and over again and you'll get the hang of it in about 3 or 4 generations of evolution.....
geposted Sun 28 Apr 02 @ 6:39 pm
